Senior Project Manager
The art of the bevel cut
These nesting tips and best practices can help deliver a quality beveled edge
- By Bruce Renfro
- Updated May 17, 2023
- January 2, 2014
It has been said that shop floor bevel cutting is as much an art as it is a science.
To cutting machine programmers new to beveling, the process can seem like an attempt to re-create a Picasso masterpiece, regardless of how much traditional cutting experience they might have. In most cases, the path to a quality beveled part evolves from hours, sometimes days, of trial and error.
Beveling spans varying levels of sophistication, cutting tools, industries, and applications—each with unique sets of challenges. Furthermore, the process can fluctuate greatly within any given industry. For example, in metal fabrication alone, thermal cutting (see Figure 1), abrasive cutting, and machining all take completely different approaches to perform bevel cuts on plate, tube, or pipe.
Make no mistake, all fabricators go through a learning curve when trying to perfect the beveling process. It is not simple high school geometry, but neither is it neurosurgery or a random act of fate.
Why Bevel?
Beveling is most prevalent in industries where heavy-duty equipment is made for off-highway, construction, agricultural, forestry, mining, oil and gas, and shipbuilding applications. Here manufacturers rely on beveling as a part of the weld preparation process. Beveled edges produce a sturdier type of weld needed to support the massive weight and loads on such machines and structures.
Another, albeit less common application is that of countersinking. Material processing equipment, such as size-reduction machinery (for example, crushers and pulverizers), generally contain replaceable steel inner liners designed to absorb shocks and extend longevity. These liners often are affixed to interior side walls using a bolted beveled metal plug or screw. The piece is countersunk into the liner, ensuring a fit that is both secure and flush.
From structural integrity all the way down to aesthetics, beveled edges are required for many applications. Regardless how simple or complex the cut, beveling requires three equally important components for predictable and repeatable success: capable hardware, sophisticated software, and knowledgeable people.
The Best Bevel Cutting Machine?
Bevel cutting machines have made great strides from the early track torches, and now advanced machinery such as high-end 5-axis cutting machines excel in delivering increasing levels of automation and performance. The results have been faster cutting with increased part quality. Today a range of bevel cutting laser, plasma, oxyfuel, and waterjet equipment (see Figure 2) is available from many of the industry’s leading cutting machine manufacturers. These companies continue to introduce new features and next-generation machines to advance the industry even further.
So with all of these options, what is the best machine for bevel cutting? It could be the one on your shop floor. Most of today’s machines are capable of high-quality bevel cuts—assuming the software and human expertise are adequate.
Software for Bevel Cutting
Because nesting software often comes preloaded on a new cutting machine, it may not receive the level of attention it deserves. When you consider the direct impact on machine performance, it becomes clear that software is much more than simply an item on a check list.
Software that may be straightforward in terms of functionality also may be limited in its functionality. In these instances, nesting software is capable of only basic part nesting and little more. More sophisticated software, however, contains advanced algorithms written to maximize throughput, part quality, and machine performance with the flexibility to drive a variety of fabrication machines. Boosting productivity while reducing material waste allows manufacturers to more quickly recoup costly machine investments.
Most important is the software’s intelligence to adapt to what is a complex application. Here are some of the areas that an automated nesting program should address in order to support beveling:
- Automatic nesting for beveled parts, taking into account extra clearances needed to accommodate the transitions between the various bevels
- Solving for feed rate and kerf scenarios when dealing with multiple-pass machines; each pass of the torch can be handled differently
- Automatic cut sequencing to ensure part integrity
- Importing of bevel attributes directly from a variety of 3-D CAD applications or from text-embedded directions within a 2-D geometry file
- Custom bevel sequence modifications
Farther on the software horizon, fabricators can expect to see significant advancements:
- The software will use a different color to distinguish between bevels that have been proven and those that are untested.
- Automatic recognition of special bevel features, such as an internal pipe fit bevel, which is a contour cut into plate so that it may accept a pipe inserted into it at an angle.
The Human Factor in the Bevel Cut
Despite tremendous functionality, technology alone does not minimize the role of the programmer or operator. The importance of the human element cannot be overstated. When it comes to fabrication in general, and beveling in particular, good people with great tools will deliver good results, but great people with great tools will achieve great beveling results.
While there is little substitute for experience, a programmer can follow proven steps to help obtain beveling success.
- Start with straight cutting on a specific thickness, and then ask yourself if the edge quality is acceptable. If not, adjust the feed rate.
- Ask if the internal and external features are dimensionally correct. If needed, adjust the kerf.
- Start the bevel cutting with a simple top knife bevel. Adjust the kerf, output angle, and feed rate if necessary.
- Begin working with other types of bevels, such as top land, bottom land, X, K, and variable (see Figure 3). After each, adjust the kerf, output angle, and feed rate if needed.
Getting the Right Bevel Cuts
What makes the bevel so different from a traditional 90-degree cut? At any given time at least three, and sometimes four, variables are in play with beveling. Feed rate, tilt angle, kerf offset, and sometimes arc voltage must all be held within tight parameters for a successful bevel cut. Such layers of complexity can make the process overwhelming for even the most veteran programmer.
Possible influences in the bevel cut exist outside the parameters of the cut itself. Cutting machines are all different, and each comes with specific OEM recommendations for operation. The manufacturing environment has a surprisingly strong influence on cut performance. For example, is beveling being performed on a wet or dry table? Is the plate level? Is a regimented procedure in place to monitor and maintain optimal cutting conditions?
At a minimum, these precutting steps should be followed for quality beveling:
- Regularly replace cutting consumables to ensure consistent cut quality.
- Consistently charge pressurized air tanks. Also, ensure that air pumped to the machine is clean and pollutant-free.
- Inspect and adjust the torch as needed before each shift.
- Check and correct machine calibration periodically. Tolerance deviations can slowly develop and manifest over time to affect cut quality.
Beveling postprocessors found in CAD software are specifically written for machines and applications. Still, some level of setup or synchronization is recommended to align the software, machine, and operator. The process is sometimes referred to as dialing in a machine. This calibration of postprocessors is especially important for beveling. It helps to have the software vendor work with new bevel customers to synchronize all of the previously mentioned variables and conditions to achieve targeted tolerances. This type of service, which includes bevel training and setup, generally runs three days or less.
The Programmer Can Make a Difference
To some, beveling remains more evolutionary than revolutionary—a tedious process based on hope and prayer, with success measured by scrap and cleanup time. It is true that most machines found on today’s shop floors, combined with robust software, offer the means to consistently produce high-quality beveled parts, but the programmer remains a wildcard in the beveling equation.
When it comes to predictable results, a fabricator can find no simple substitute for experience. But that doesn’t mean a programmer has to become an expert overnight. A programmer needs to become familiar with the basics of beveling and the steps needed to correct miscues. From there, experience will build.
If you are going to get behind the wheel and race, you don’t need to know how to rebuild the engine, but you should at least learn how to drive a stick.
Bruce Renfro
1445 Kemper Meadow Drive
Cincinnati, OH 45240
513-674-0005
